Sapim CX-Ray Spokes, White
Sapim CX-Ray Spokes, White 236 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 238 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 240 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 242 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 244 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 246 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 248 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 250 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 252 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 254 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 256 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 258 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 260 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 262 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 264 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 266 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 268 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 270 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 272 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 274 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 276 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 278 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 280 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 282 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 284 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 286 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 288 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 290 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 292 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 294 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 296 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 298 mm $5.00 In Stock
Sapim CX-Ray Spokes, White 300 mm $5.00 In Stock
Weight4.8 - 5.0 grams each
Materialcold forged stainless steel
Blade Dimensions2.3 x 1.3 mm
Thread2.2 x 56 tpi (2.0mm, 14g)
Sapim, a Belgian company founded in 1918, has been producing high quality spokes for the better part of a century. Combining their extensive experience and a commitment to innovation, Sapim is able to produce the best quality spokes available today. Sapim's success with providing companies such as Zipp and Shimano with OE spokes, as well as their ongoing support of and feedback from professional racers speaks volumes to their confidence.
The CX-Ray is Sapim's flagship high performance spoke. Don't let the low weight of these spokes fool you; the CX Ray's tested tensile strength is nearly 50% better than a standard straight gauge spoke, with a fatigue life three times as long! These spokes hold their own under the world's best athletes; road racers, triathletes, and even downhill racers. Consequently, the CX-Ray is the go-to spoke for any high end wheelset, from low spoke count sub-800 gram climbing wheels to ultra-durable, high-strength 32 spoke mountain wheels. These are the lightest and most durable stainless steel spokes available today.
These CX-Ray spokes are factory finished with durable white powdercoat.
Ordering
Please note that Sapim spokes measure about 1 mm shorter than the listed length (e.g. 282 spoke length is actually 281 mm). Virtually any length can be custom cut in-house, and we are happy to provide assistance in calculating spoke lengths; contact us here. These spokes are sold individually and do not include nipples.
Assembly
We recommend that high end wheels built with CX-Ray spokes be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and rim selections. Please contact us directly or submit a custom wheel build request here.
While these spokes do not require any special wheel building techniques, the thin bladed section must be supported near the nipple to prevent helical twisting. With a 2.3 mm wide blade, the CX Ray does not require slotting of the hub's spoke holes.
Comment on Sapim CX-Ray Spokes, White
