Ritchey Torqkey 4mm, 5Nm
You just spent a small fortune outfitting your bike with carbon components. Betting you can feel 5 newton meters just isn't good enough to ensure
you don't over torque the fixing bolts and ruin your carbon. The Ritchey Torqkey is your solution. The Torqkey features a 4mm bit, a common size used in many stems and it is pre-set to the most common toque spec of 5Nm. As parts get lighter and lighter, the torque wrench is quickly becoming the most important tool in your box. Don't leave it to chance, get the Torqkey.
