Road Rims
Specifications Weight375 grams Width21 mm Depth13 mm Available Drillings28, 32 hole Tire Compatibilitytubular, 28" ERD612 mm Detail Ambrosio's...
$80.002 options.View
Specifications Weight455 grams Width19.2 mm Depth18.5 mm Available Drillings28, 32 hole Tire Compatibilityclincher, 700c (ISO 622) ERD602 mm Detail...
$100.002 options.View
Specifications Weight460 grams Width21 mm Depth13 mm Available Drillings32 hole Tire Compatibilitytubular, 28" ERD612 mm Detail The Nemesis may be...
$105.001 options.View
Specifications Weight260 grams Width21 mm Depth25 mm Available Drillings20, 24, 28 hole Tire Compatibilitytubular, 28" ERD607 mm About Enve...
$780.0012 options.View
Specifications Weight295 grams Width21.5 mm Depth45 mm Available Drillings20, 24 hole Tire Compatibilitytubular, 28" ERD564 mm About Enve...
Specifications Weight360 grams Width21.5 mm Depth65 mm Available Drillings16, 20, 24, 28 hole Tire Compatibilitytubular, 28" ERD527 mm About Enve...
$780.0011 options.View
Specifications Weight450 grams Width21.5 mm Depth45 mm Available Drillings18, 20, 24, 28 hole Tire Compatibilityclincher, 700c (ISO 622) ERD564 mm ...
$875.0013 options.View
Specifications Weight485 grams Width21.5 mm Depth65 mm Available Drillings16, 20, 24, 28 hole Tire CompatibilityClincher, 700c ERD527 mm About Enve...
$875.0011 options.View
Specifications Weight, Front355 grams Weight, Rear380 grams Width, Front26 mm Width, Rear24 mm Depth, Front35 mm Depth, Rear45 mm Available...
$975.004 options.View
Specifications Weight, Front455 grams Weight, Rear485 grams Width, Front26 mm Width, Rear24 mm Depth, Front60 mm Depth, Rear70 mm Available...
Specifications Weight470 grams Width23 mm Depth24 mm Materialaluminum alloy Available Drillings24, 28, 32 hole Tire Compatibility700c clincher (ISO...
$120.004 options.View
Specifications Weight440 grams Width23 mm Depth24 mm Materialaluminum alloy Available Drillings24, 28 hole Tire Compatibility28" tubular ERD592 mm ...
$120.002 options.View
Specifications Weight440 grams Width18.5 mm Depth25.0 mm Available Drillings20, 24, 28, 32 hole Available Colorsblack Tire Compatibility28" tubular...
$60.004 options.View
Specifications Weight410 grams Width20 mm Depth21 mm Available Drillings20, 24, 28 hole Tire Compatibility700c clincher (ISO 622) ERD598 mm Detail...
$65.003 options.View
Specifications Weight390 grams Width19 mm Depth22 mm Available Drillings20, 24, 28, 32 hole Available Colorssilver, black Tire Compatibility700c...
$55.006 options.View
Specifications Weight445 grams Depth27 mm Sidewall Width19 mm Tire Compatibility700c clincher Available Drillings20, 24, 28, 32 Available...
$55.0011 options.View
Specifications Weight 455 grams Depth 30 mm Sidewall Width 19 mm Tire Compatibility 700c clincher Available Drillings 16, 20, 24, 28, 32 ...
$60.0015 options.View
Specifications Weight550 grams Depth38 mm Width20 mm ERD563 Detail The XR-380 has the deepest section in KinLin's rim line, and is one of the...
Specifications Weight462 grams Width21.5 mm Depth46 mm Available Drillings20, 24 hole Tire CompatibilityTubular, 28" ERD568 mm About Reynolds...
$850.001 options.View
Specifications Weight334 grams Width21.5 mm Depth46 mm Available Drillings20, 24 hole Tire CompatibilityTubular, 28" ERD568 mm About Reynolds...
$800.00 $600.00Save: $200.00 off
2 options.View
Specifications Weight562 grams Width21.5 mm Depth66 mm Available Drillings16, 20, 24 hole Tire CompatibilityClincher, 28" ERD530 mm About Reynolds...
$850.00 $637.50Save: $212.50 off
2 options.View
Specifications Weight478 grams Width21.5 mm Depth66 mm Available Drillings16, 20, 24 hole Tire CompatibilityTubular, 28" ERD528 mm About Reynolds...
3 options.View
Specifications Weight~355 grams Width21 mm Depth22 mm Available Drillings20, 24, 28, 32 hole ERD591 mm Detail Exceedingly smooth, extraordinarily...
$120.005 options.View
Specifications Weight, Black440 grams Weight, White455 grams Width22.8 mm Depth19.2 mm Available Drillings20, 24, 28 hole Tire...
$80.007 options.View
