Rim Tape, Valves, Etc.
Enve Valve Extender
Specifications Weight, 39 mm2.1 grams Weight, 55 mm3.1 grams Detail These original replacement valve extenders from Enve are designed to fit their...
$8.00
2 options.View
KCNC Valve Extenders
Specifications Weight, 50 mm2.2 grams each Weight, 85 mm4.2 grams each Valve CompatibilityPresta Detail KCNC's lightweight valve extenders are a...
$12.00
7 options.View
Rox Ultralite Rim Strip
Rox Ultralite rim strips are manufactured from lightweight puncture-resistant nylon with a super sticky adhesive backing. The lightest rim strip on...
$13.00
3 in stock.View
Stan's NoTubes Tire Sealant
Specifications Weight25 grams per fluid ounce Detail Stan's Sealant is the foundation of their tubeless conversion business, and arguably the best...
$3.00
2 options.View
Stan's NoTubes Rim Tape
Specifications Weight, 12 mm3 grams per rim Weight, 21 mm5 grams per rim Weight, 25 mm7 grams per rim Length per Roll10 yards Detail Stan's yellow...
$6.00
3 options.View
Stan's Tubeless Valve Stem
Specifications Weight, 35 mm6.5 grams Weight, 44 mm7.5 grams Detail Stan's No Tubes valve stems are designed for tubeless conversion of their ZTR...
$8.00
2 options.View
Velocity Veloplugs
Specifications Weight Each ~.15 grams Weight per 16 2.5 grams Weight per 20 3.0 grams Weight per 24 3.7 grams Weight per...
$0.25
2 options.View
