Mountain Rims
Specifications Weight235 grams Width24 mm Depth32 mm Available Drillings24, 28, 32 hole Tire Compatibility26" tubular ERD533 About Enve Composites...
$780.003 options.View
Specifications Weight350 grams Width24 mm Depth32 mm Available Drillings28, 32 hole Tire Compatibility26" clincher (ISO 559), 26" UST ERD533 About...
$860.002 options.View
Specifications Weight290 grams Width24 mm Depth32 mm Available Drillings28, 32 hole Tire Compatibility29" tubular ERD595 mm About Enve Composites...
$875.002 options.View
Specifications Weight385 grams Width24 mm Depth32 mm Available Drillings28, 32 hole Tire Compatibility29" clincher (ISO 622), 29" UST ERD595 About...
$890.002 options.View
Specifications Weight, black430 grams Weight, white450 grams Width24 mm Depth20 mm Usecross country, disc only ERD539 mm Detail The XD-230 rim...
$55.00 $44.00Save: $11.00 off
2 options.View
Specifications Weight, black495 grams Weight, white520 grams Width24 mm Depth20 mm Usecross country, disc only ERD602 mm Detail The XD-230 rim...
2 options.View
Specifications Weight360 grams Width24.4 mm Depth16.0 mm Available Drillings32 hole Tire Compatibility650b (ISO 584) clincher and tubeless ready...
$88.001 options.View
Specifications Weight330 grams Width23.0 mm Depth17.4 mm Available Drillings28, 32 hole Tire Compatibility26" (ISO 559) clincher and tubeless ready...
$88.002 options.View
Specifications Weight340 grams Width24.4 mm Depth16.0 mm Available Drillings28, 32 hole Tire Compatibility26" (ISO 559) clincher and tubeless ready...
Specifications Weight380 grams Width24.4 mm Depth16.0 mm Available Drillings32 hole Tire Compatibility29" (ISO 622) clincher and tubeless ready...
