Race Face Bottom Bracket
Race Face Bottom Bracket BB92 $60.00 In Stock
Race Face Bottom Bracket BSA 68MM / 73MM $60.00  1 Remaining
Race Face Bottom Bracket PF30 $60.00 In Stock
Details
If you need a durable, long wearing bottom bracket, consider this offering from Race Face. They come factory filled with Phil Wood grease for smooth operation. The crank spindle is supported by standard 6806 bearings. The whole assembly is sealed from the elements by an internal liner. Suitable for use in XC/AM/FR/DH.
In order to install the Race Face BSA bottom bracket that accommodates a 30 mm crank spindle, Race Face's own Cinch Bottom Bracket Wrench must be used. To avoid frame damage, we recommend the press fit bottom brackets be professionally installed using a proper bearing press.
Comment on Race Face Bottom Bracket
