Pumps/Inflation
KCNC Pump Head
Specifications Valve compatibility Presta only Detail KCNC's pump head provides a great aftermarket upgrade option for the most common...
$40.00
7 in stock.View
Lezyne Alloy Floor Drive
CNC machined aluminum barrel and foot; steel piston Varnished wood handle with CNC machined aluminum center lug Alloy Flip-Thread chuck threads...
$69.00
2 options.View
Lezyne CNC Floor Drive
All parts are custom, CNC machined aluminum100% aluminum Flip-Thread chuck threads securely to both Presta and Schrader valvesFlip-Thread chuck and...
$99.00
2 options.View
Lezyne Road Drive
The Lezyne Road Drive is the premier pump for inflating your road tires with a hand-pump. It's rated to inflate up 160psi, but unless you've got...
$45.00
4 options.View
Lezyne Steel Floor Drive
Alloy foot, steel barrel and piston Varnished wood handle 47”/120cm extra-long, premium-grade hose Presta/Schrader compatible head Long travel...
$49.00
2 options.View
Silca Disc Adapter 25.0
Disc wheel pump adapter. Features a threaded end that easily attaches to the Schrader port of most pumps. It can also just be inserted into the hose...
$15.95
0 in stock.View
