Pro Allen Wrench Set
Sign Up For Our Newsletter
You're Signed Up!
Sizes4mm, 5mm, 6mm, 8mm
Pro Allen Wrench Set 4mm, 5mm, 6mm, 8mm $55.00 In Stock
Details
A comfortable ergonomic T-handle allen wrench set with a patented end to assist in removing wallowed out or stripped bolts. Ideal for shop mechanics or the concerning home mechanic.
Removing Stripped Bolts
On the end of the longer allen there is a small slice of the wrench that is bolted off center to the rest of the T-handle. When the two lines on the sliver and the wrench line up the sliver is flush with the tool and operates normally. When inserted into a stripped nut and turned the eccentric sliver rotates off center effectively expanding the allen wrench. It simply bites into the remaining metal in the bolt and assists in the removal.
