Praxis Standard Bottom Bracket
Sign Up For Our Newsletter
You're Signed Up!
Weight: Road 91.3 grams
Weight: Mountain 102.1
Material 7075 T6 Aluminum
Bearing Material 6805 Stainless Steel
Product Manuals
Praxis Full Warranty Policy
Praxis Standard Bottom Bracket Mountain 68/73MM $40.00  1 Remaining
Praxis Standard Bottom Bracket Road 68MM $40.00  1 Remaining
Details
These precision machined bottom brackets are a long lasting, freely spinning and competitively priced alternative to other options. The cups are CNC’d out of 7075 T6 Aluminum and the bearings feature high-grade 6805 stainless steel balls. These bottom brackets are a great replacement for use with 24mm spindle cranksets, like Shimano’s Hollowtech II crankset.
