Praxis Ceramic Conversion BB
Sign Up For Our Newsletter
You're Signed Up!
Praxis Conversion BB Specifications
Crank Compatability Shimano™ 24mm Hollowtech
Bearings Ceramic 6805
Bottom Bracket Compatability
PF30 / BB30, 68mm 68mm PF30, 68mm BB30
PF30 / BB30, 73mm 73mm PF30, 73mm BB30
OSBB Any Specialized OSBB Frame
Product Manuals
Praxis Conversion BB Instructions
Praxis Full Warranty
Praxis Conversion BB Chart
Praxis Ceramic Conversion BB BB30 / PF30, 68 mm $195.00 Notify Me When Available
Praxis Ceramic Conversion BB BB30 / PF30, 73 mm $195.00 In Stock
Praxis Ceramic Conversion BB OSBB, 68 mm $195.00 In Stock
Details
Praxis' ceramic conversion bottom bracket provides a strong and reliable platform to run Shimano™ 24mm spindle cranks with a BB30 or Pressfit 30 (PF30) frame. Similar to the stainless steel version of the Praxis Conversion BB in all respects except one: the bottom bracket been upgraded to utilize hybrid ceramic bearings for extended wear life and less friction. The best conversion BB choice on the market just got better.
The strength of this conversion BB lies in its threaded design. The non-drive side cup is press fit into the frame providing an interface similar to other bottom bracket conversions on the market. Where the Praxis design differs is in its use of a threaded drive side cup. Using a Shimano BB tool the drive side threads into the non-drive side sleeve. The last millimeter, or so, of threads expand the non-drive shell creating a stronger friction hold than a simple press fit bottom bracket could. Furthermore the threaded design perfectly aligns the BB in your frame and prevents any walking out or wobbling of the bearings under load.
Compatibility
The Praxis Bottom Bracket Conversion comes with a sleeve to fit PF30 frames. The sleeve will need to be press fit into the frame before threading in the BB30 converter. For a BB30 frame the sleeve can simply be discarded and the BB30 adapter installed.
OSBB Compatibility
The newest Praxis BB adapter works with a Specialized OSBB frame to a standard 24mm Shimano type crank.
Di2 / EPS Compatibility
The new BB30 conversion has wiring holes drilled into it for internally routed wiring. The PF30 sleeve does not have the same holes.
Media Links
  • Installation Video
  • "Praxis Works showed what we feel is the most thoroughly designed BB/PF30-to-24mm bottom bracket adapter currently on the market." - James Huang, Cyclingnews / Bike Radar [Link]
