Powertap G3 Rear Hub
Weight 337 grams
Spacing 130mm
Axle 15 mm Alloy
Available Drillings 24, 28 hole
Available Colors black
Use Road Only
Battery CR2032
Acuracy +/- 1.5% (claimed)
Compatability
Saris Joule w/ GPS
Garmin Edge 800
Edge 705
Edge 500
Forerunner 310XT
Forerunner 910XT GPS
Wheel Building Dimensions
Flange diameter 57.0 mm
Hub center to flange 17.4 (Drive Side)
38.0 (Non-Drive Side)
Powertap G3 Rear Hub 24 Hole $1,299.00 In Stock
Powertap G3 Rear Hub 28 Hole $1,299.00 Notify Me When Available
Powertap G3 Rear Hub Campagnolo Freehub Body $125.00 Notify Me When Available
Powertap G3 Options
The G3 is available in Campagnolo or Shimano 11-speed freehub bodies. If you'd like a Campagnolo version leave us a note during the ordering process and we'll covert the freehub body free of charge.
Powertap G3 Details
The G3 Powertap is CycleOps' high performance hub weighing in at 337g, their lightest hub yet. Furthermore the G3 features a completely redesigned hub shell featuring a 5mm wider flange spacing aimed at increased wheel strength and durability. The new hub is matte black with subtle gloss black CycleOps logos wrapped around the shell, very much matching the gloss logos on ENVE'sSmart rims.
The G3 will be compatible with any existing ANT+ enabled Garmin unit allowing a seamless integration into your current setup. Although the new hub is not compatible with the older egg-shaped yellow Powertap head unit, their new ANT+ Joule and Joule GPS units are designed around the G3 hub.
One final yet very important change to the G3 is the ease of serviceability. The wireless transmitter no longer sits inside the hub which allows for a smaller hub diameter and easier removal. With common tools the transmitter can be removed and sent for repair or replace without sending the wheel back to Saris.
Wheel Building using the Powertap G3
We recommend that wheels with Powertap hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild here .
Comment on Powertap G3 Rear Hub
