Power Cordz Windsor Brake Clasps
Power Cordz Windsor Brake Clasps 5 mm$11.00 In Stock
Power Cordz Windsor Brake Clasps 6 mm$11.00  2 Remaining
Power Cordz Windsor Brake Clasps Zero Gravity / KCNC$11.00 Notify Me When Available
Weight 2.0 grams per pair
Compatibility (5mm, 6mm) All Campagnolo and SRAM Force brake calipers, as well as many aftermarket brakes
Compatibility (Zero Gravity, KCNC) Zero Gravity, Negative Gravity, and KCNC road brake calipers
Contains
Included are two sets of Windsor brake clasps, which are installed in place of your brake's stock pinch bolt washers. These are compatible with most brakes on the market, including Campagnolo, Shimano, and Sram. Some aftermarket brakes (including Zero Gravity and KCNC) will require the M4 clasps, which must be purchased separately.
Details
The Windsor Clasp was developed by Power Cordz to simplify the brake cable mounting system. This clasp replaces the stock washer and allows the installer to simply wrap the Power Cordz cable 360 degrees around the pinch bolt for a safe and secure connection. The result is a much cleaner look and faster, less frustrating installation.
For installation instructions, click here.
Comment on Power Cordz Windsor Brake Clasps
