Power Cordz Prime Derailleur System
Power Cordz Prime Derailleur System Black $79.00 In Stock
Power Cordz Prime Derailleur System Blue $79.00  1 Remaining
Power Cordz Prime Derailleur System Red $79.00 In Stock
Power Cordz Prime Derailleur System White $79.00 In Stock
Weight, complete system 64 grams
Package Contents
1.2mm shifter Cordz - 2 ea
Pre-lubed 5mm housing (2m length) - 1 ea
lined ferrules - 8 ea
Grommet Clasp - 4 ea
Protective Liners - 2 ea
Instruction sheet and sticker - 1 ea
The next generation of shifter cable control systems. IoDupont's Power Cordz cable systems introduce several new innovations over the traditional steel cable. Power Cordz are lighter, more durable, and perform better than steel cables over a longer period. Each of these next generation cables contain thousands of Zylon fiber strands, one of the strongest super-fibers known to man. These fibers are coated with a nylon sleeve for protection, optimum performance, and long life. These combined characteristics make Power Cordz the best performing and most durable cable on the market.
  • Over 75% lighter than steel cables
  • Smooth, responsive control - high flexibility, low friction
  • Durable, dependable, and no corrosion - PowerCordz will not rust, and the smooth coating resists grime buildup.
  • Low maintenance - fewer adjustments needed over the life of your cable system
Click here for IoDupont's installation instructions.
Comment on Power Cordz Prime Derailleur System
