Power Cordz Prime Brake System
Power Cordz Prime Brake System Mountain, Black $79.00 In Stock
Power Cordz Prime Brake System Road, Black $79.00 Notify Me When Available
Power Cordz Prime Brake System Road, Red $79.00 In Stock
Power Cordz Prime Brake System Road, White $79.00 In Stock
Weight, complete mountain system 95 grams
Weight, complete road system 85 grams
Package Contents
1.75mm brake Cordz - 2 ea
Pre-lubed 5mm housing (1.8m length) - 1 ea
2009 Winsor Clasp (6mm) - 2 ea
6mm lined ferrules - 6 ea
5mm lined ferrule - 2 ea
Instruction sheet and sticker - 1 ea
Included in Mountain Systems
v-brake noodle - 2 ea
v-brake noodle gator - 2 ea
The next generation of brake cable control systems. IoDupont's Power Cordz cable systems introduce several new innovations over the traditional steel cable. Power Cordz are lighter, more durable, and perform better than steel cables over a longer period. Each of these next generation cables contain thousands of Zylon fiber strands, one of the strongest super-fibers known to man. These fibers are coated with a nylon sleeve for protection, optimum performance, and long life. These combined characteristics make Power Cordz the best performing and most durable cable on the market.
  • Over 75% lighter than steel cables
  • Smooth, responsive control - high flexibility, low friction
  • Durable, dependable, and no corrosion - PowerCordz will not rust, and the smooth coating resists grime buildup.
  • Low maintenance - fewer adjustments needed over the life of your cable system
Click here for IoDupont's installation instructions.
Links
Power Cordz Brake Cable Set - cables only, no housing.
Comment on Power Cordz Prime Brake System
