Power Cordz Derailleur System
Power Cordz Derailleur System 5 mm, Black $68.00
$54.40
You Save: $13.60
Notify Me When Available
Closeout - 5 mm Derailleur System
20% Discount!
Details
Experience the next generation of cycling cable control systems! IoDupont's Power Cordz cable systems introduce several new innovations over the traditional steel cable. Power Cordz are more lightweight (45-60g over traditional steel cables), more durable, and perform better than steel cables over a longer period. Each of these next generation cables contain thousands of Zylon fiber strands, one of the strongest superfibers known to man. These fibers are coated with a nylon sleeve for protection, optimum performance, and long life. These combined characteristics make Power Cordz the best performing and most durable cable on the market.
  • Over 75% lighter than steel cables
  • Smooth, responsive control - high flexibility, low friction
  • Durable, dependable, and no corrosion - PowerCordz will not rust, and the smooth coating resists grime buildup.
  • Low maintenance - fewer adjustments needed over the life of your cable system
Click here for IoDupont's installation instructions
Comment on Power Cordz Derailleur System
