Power Cordz Brake System Prime
Power Cordz Brake System Prime Mountain, Black$79.00 In Stock
Power Cordz Brake System Prime Road, Black$79.00 In Stock
Power Cordz Brake System Prime Road, Red$79.00 In Stock
Power Cordz Brake System Prime Road, White$79.00 In Stock
Weight, complete mountain system95 grams
Weight, complete road system85 grams
Contents
2 ea - 1.75mm brake Cordz
1 ea - pre-lubed 5mm housing - 1.8m length
2 ea - 2009 Winsor Clasp - 6mm
6 ea - 6mm lined ferrules
2 ea - 5mm lined ferrule
1 ea - Instruction sheet and sticker
Included only in mountain systems:
2 ea - v-brake noodle
2 ea - v-brake noodle gator
Experience the next generation of cycling cable control systems! IoDupont's Power Cordz cable systems introduce several new innovations over the traditional steel cable. Power Cordz are lighter, more durable, and perform better than steel cables over a longer period. Each of these next generation cables contain thousands of Zylon fiber strands, one of the strongest super-fibers known to man. These fibers are coated with a nylon sleeve for protection, optimum performance, and long life. These combined characteristics make Power Cordz the best performing and most durable cable on the market.
  • Over 75% lighter than steel cables
  • Smooth, responsive control - high flexibility, low friction
  • Durable, dependable, and no corrosion - PowerCordz will not rust, and the smooth coating resists grime buildup.
  • Low maintenance - fewer adjustments needed over the life of your cable system
Click here for IoDupont's installation instructions.
Links
Power Cordz Brake Cable Set - cables only, no housing.
Comment on Power Cordz Brake System Prime
