Power Cordz Brake Cable Set
Power Cordz Brake Cable Set Mountain, Black $37.00 In Stock
Power Cordz Brake Cable Set Mountain, White $37.00
$29.60
You Save: $7.40
In Stock
Power Cordz Brake Cable Set Road, Black $37.00  1 Remaining
Power Cordz Brake Cable Set Road, Blue $37.00 In Stock
Power Cordz Brake Cable Set Road, Red $37.00 In Stock
Power Cordz Brake Cable Set Road, White $37.00 In Stock
Power Cordz Brake Cable Set Road, Yellow $37.00 In Stock
Closeout - Colored MTB Brake Cordz
20% Discount!
Weight 5 grams per cable
Colors black, blue, red, white, yellow
Diameter 1.75 mm
Length 1.7 meters
Contains
2 ea. - 1.75 mm Brake Cordz
Details
Experience the next generation of cycling cable control systems! IoDupont's Power Cordz cable systems introduce several new innovations over the traditional steel cable. Power Cordz are more lightweight, more durable, and perform better than steel cables over a longer period. Each of these next generation cables contain thousands of Zylon fiber strands, one of the strongest superfibers known to man. These fibers are coated with a nylon sleeve for protection, optimum performance, and long life. These combined characteristics make Power Cordz the best performing and most durable cable on the market.
  • Over 75% lighter than steel cables
  • Smooth, responsive control - high flexibility, low friction
  • Durable, dependable, and no corrosion - PowerCordz will not rust, and the smooth coating resists grime buildup.
  • Low maintenance - fewer adjustments needed over the life of your cable system
Comment on Power Cordz Brake Cable Set
