Pillar Mega Lite SS Spoke
Pillar Mega Lite SS Spoke 244-250 mm $6.50  50 Remaining
Pillar Mega Lite SS Spoke 258-264 mm $6.50 In Stock
Pillar Mega Lite SS Spoke 264-270 mm $6.50 In Stock
Pillar Mega Lite SS Spoke 270-278 mm $6.50 In Stock
Pillar Mega Lite SS Spoke 280-286 mm $6.50 In Stock
Pillar Mega Lite SS Spoke 284-290 mm $6.50 In Stock
Pillar Mega Lite SS Spoke 290-296 mm $6.50 In Stock
Ordering
Since the Mega Lite Spokes are listed as a range please specify in the order notes the exact length you'd like us to cut the spoke to. If you don't specify a length you'll receive the longest length listed in the range. The spokes can safely be cut down 6mm from there.
Mega Lite Spoke Dimensions
Weight 3.5g - 3.8g
Material Stainless Steel
Blade Dimensions 1.6mm x 0.9mm
Thread 2.2 x 56 tpi (2.0mm, 14g)
Head Type J-bend, 2.0mm
Mega Lite SS Detail
Like other companies we work with (Praxis for example) Pillar has been an OEM manufacturer for different companies we've all heard of for years. Their experience, choice of materials and capabilities have made them a go to vendor for some of the largest wheel manufacturers and suppliers in the world. Drawing on that experience we can say that we're happy to offer Pillar spokes and believe they will find a home with our customers and on our custom wheel builds.
The Mega Lite SS spoke is the lightest steel spoke on the market. And it is a 2.0mm spoke; the Mega-Lites maintain compatibility with the most common nipples on the market, all without sacrificing strength at the spoke head or nipple. Their Stainless Steel compound and manufacturing process results in a spoke with a center section that can safely be drawn to a 1.3mm diameter, compared to 1.5mm (Sapim CX-Ray, DT Swiss Aerolite and Revolution) and 1.4mm (CX-Ray Super). This allows the ends to maintain the 2.0mm diameter and bypassing the compromise of dropping to 1.8mm for its weight savings. The center is then cold forged into a 1.6mm x 0.9mm blade using a similar process to the Sapim CX-Rays and DT Aerolites.
Thread Compatibility
It seems every company has a slightly different way of measuring spoke threads. We've standardized our dimensions to provide a comparable figure. The Pillar website lists the Mega Lite SS threads as 2.3mm X 56 TPI. Our measurments show a 2.2mm X 53 TPI the same as CX-Ray and other common spokes. The Mega Lite SS spokes are compatible with standard nipples.
Comment on Pillar Mega Lite SS Spoke
