Pillar Aluminum Internal Nipple
In Stock
$1.00
Add to Cart:
Weight.38 grams each
Length9.4 mm
Material7075 aluminum
Tool Fitting3/16" hex
Compatible Thread2.2 mm x 56 tpi (2.0 mm spokes)
These high quality aluminum nipples from spoke manufacturer Pillar are intended for use with modern rims where the spoke threads and nipple are located inside the rim cavity. Manufacturers such as Reynolds and Enve Composites design their carbon fiber rims specifically for use with this nipple. Use of an internal nipple allows for smaller spoke holes which distributes force from spoke tension over a larger area.
We only recommend these nipples for use in rims with ~2.3 mm spoke holes.
Assembly
Pillar internal nipples must be properly oriented to prevent rim damage. The outward facing side features a cylindrical tool catch, while the inward facing side features a spherical surface and recessed threads. To properly tighten these nipples, an internal spoke wrench with a 3/16" hex socket is required.
Recommended Tools
IceToolz Internal Nipple Wrench
Alchemy Bladed Spoke Holder
