Parts of Passion Chainring Bolts
Parts of Passion Chainring Bolts Black$40.00 Notify Me When Available
Parts of Passion Chainring Bolts Blue$40.00 Notify Me When Available
Parts of Passion Chainring Bolts Copper Brown$40.00 Notify Me When Available
Parts of Passion Chainring Bolts Crystal Green$40.00 Notify Me When Available
Parts of Passion Chainring Bolts Gold$40.00  2 Remaining
Parts of Passion Chainring Bolts Green$40.00 In Stock
Parts of Passion Chainring Bolts Lagoon Blue$40.00 Notify Me When Available
Parts of Passion Chainring Bolts Orange$40.00 In Stock
Parts of Passion Chainring Bolts Red$40.00 Notify Me When Available
Parts of Passion Chainring Bolts Rose Pink$40.00  2 Remaining
Parts of Passion Chainring Bolts Silver$40.00  1 Remaining
Parts of Passion Chainring Bolts Titanium$40.00 In Stock
Parts of Passion Chainring Bolts Violet$40.00 Notify Me When Available
Weight9.8 grams per set
Material7075 T6 aluminum
Bolt Threadm8 x 5 mm
Nut Threadm8, 6.8 mm sleeve
Swiss machining specialist Parts of Passion precisely manufactures these road double chainring bolt sets in a dazzling array of anodized colors. Beyond their elegant appearance, these chainring fastener sets are intelligently designed, with torx wrench fittings on both the bolt and the nut. This small detail allows for easier installation and removal, while greatly reducing the possibility of stripping or otherwise damaging the tool socket.
A T30 and a T40 torx wrench are required for proper installtion of these chainring bolts. Prior to installation, grease or medium strength threadlocker should be applied to the bolt threads. Parts of Passion recommends that the bolt be tightened with a torque wrench to 13 Nm.
Comment on Parts of Passion Chainring Bolts
