Parlee PF30 Bottom Bracket Adapter
Frame Compatibility Press Fit 30 (PF30)
Weight
Shimano 102 grams
Campagnolo 88 grams
Crankset Compatibility
Shimano
Hollowtech II (68mm)
105, Dura-Ace, Ultegra, and any other Hollowtech II compatible 24mm axle.
Shimano
Hollowtech II (73mm)
XTR, XT, Saint, SLX, CX-70, CX-50, and any other Hollowtech II compatible 24mm axle.
Campagnolo Ultra Torque™
Bearing Size
Shimano 2437 (2)
Included
Campagnolo 6805w6 (2)
Not Included
Parlee PF30 Bottom Bracket Adapter Campagnolo Ultra Torque $90.00  1 Remaining
Parlee PF30 Bottom Bracket Adapter Shimano HTII $90.00 Notify Me When Available
Parlee PF300 Bottom Bracket Adaptor Details
This bottom bracket adapter is supplied by Parlee to seamlessly adapt their PF30 bottom brackets to Shimano's 24 mm Hollowtech II or Campagnolo's Ultra Torque™ spindle standards. These adapters will, however, work in any manufacturer's PF30 bottom bracket. The Shimano bottom bracket's cups are equipped with high quality Enduro ABEC 5 bearings with additional external seals to ensure long bearing life regardless of the riding conditions.
A bearing press with appropriate drift sizes will be required to properly install this bottom bracket and prevent damage to the frame. For this reason, we recommend that installation be performed by an experienced mechanic.
Comment on Parlee PF30 Bottom Bracket Adapter
