Parlee BB30 Shimano HTII Adapter Bottom Bracket
Weight102 grams
Crankset CompatibilityShimano HTII
Bearing Size2437 (2)
This bottom bracket adapter is supplied by Parlee to seamlessly adapt their Z5 BB30 bottom brackets to Shimano's 24 mm Hollowtech II spindle standard. These adapters will, however, work in any manufacturer's BB30 bottom bracket. The bottom bracket's cups are equipped with high quality Enduro ABEC 5 bearings with additional external seals to ensure long bearing life regardless of the riding conditions.
A bearing press with appropriate drift sizes will be required to properly install this bottom bracket and prevent damage to the frame. For this reason, we recommend that installation be performed by an experienced mechanic.
