Nokon Alloy Shift Housing for Shimano
Nokon Alloy Shift Housing for Shimano Gold$93.00  $74.40
Save: $18.60 off
Notify Me When Available
Nokon Alloy Shift Housing for Shimano Silver$93.00  $74.40
Save: $18.60 off
 1 Remaining
Weight 40g per meter (housing and liner)
Colors Black, Blue, Gold, Red, Silver, White
Details
Nokon aluminum housing systems provide a superior alternative to traditional housings of steel and plastic. Nokons are lighter, more attractive, and offer increased performance advantages for both shift and brake systems. This unique, patented system is composed of 9mm jointed aluminum sections which are strung together on a low-friction glass teflon liner. The nature of these jointed sections allow them to be run in shorter sections with tighter cable bends than traditional housing. And while the housing is much more laterally flexible, it is extremely resistant to linear compression from cable pull. This results in quicker, more precise shifting and a more powerful braking response. With both systems, the amount of hand stregth required to shift or brake is reduced as well. Other benefits over traditional systems include:
  • up to 40% weight reduction in the cable system
  • more resistant to rusting and corrosion; longer lasting
  • aluminum sections are interchangeable, reuseable, and recycleable
  • housing is stronger, with a greater resistant to impact from crashes
  • many available colors which may be combined for a unique, custom look
This Nokon housing kit features a complete set of housing sections, liners, stainless steel cables, cable tips, and frame savers for two (front and rear) Shimano shift systems. The aluminum housing sections are black anodized. The liners are easily cut and the sections reorganized to permit custom sizing. Installation instructions are included.
Comment on Nokon Alloy Shift Housing for Shimano
