New Ultimate Low Rise Scandium Handlebar
Sign Up For Our Newsletter
You're Signed Up!
Material Scandium
Weight 178.7 g
Clamp 31.8
Width 670mm
New Ultimate Low Rise Scandium Handlebar Black $85.00 In Stock
This is the low rise version of New Ultimate's popular Aluminum handlebar that's been extremely popular due to it's weight. The handlebar tubing is reinforced at the stem clamp section and aggressively butted toward the outer sections. Despite the super thin wall thickness, the scandium material is sufficiently strong enough to support the use of bar ends. Each bar has an ergonomically friendly 5 degree sweep, and an oversize 31.8 mm stem clamp. New Ultimate logos and tilt marks are laser etched on the bar's bead blasted and black anodized surface.
Comment on New Ultimate Low Rise Scandium Handlebar
