New Ultimate Evo Mountain Bike Handlebar
Sign Up For Our Newsletter
You're Signed Up!
Weight, Flat111 grams
Weight, Riser128 grams
MaterialUD carbon fiber
Length700 mm
Can be cut to 620mm
Stem Clamp Diameter31.8 mm
Back Sweep, Flat 7.5 degrees
Back Sweep, Riser9 degrees
Bar Ends Not Compatable
Maximum Torque Setting9Nm
Weight Limit 88kg / 195lbs
New Ultimate Evo Mountain Bike Handlebar Gloss, 62cm $160.00 Notify Me When Available
New Ultimate Evo Mountain Bike Handlebar Gloss, 70cm $160.00 Notify Me When Available
New Ultimate Evo Mountain Bike Handlebar Matte, 70cm $160.00 Notify Me When Available
New Ultimate Evo Mountain Bike Handlebar Gloss, 70 cm, Riser $180.00 Notify Me When Available
New Ultimate Evo Mountain Bike Handlebar Matte, 70 cm, Riser $180.00  1 Remaining
Details
New Ultimate's carbon mountain bike handlebar is extremely light for a 700mm wide bar, weighing around 10 grams lighter than the lightest offerings. Specially constructed for the rider who is as conscious about build weight as they are with component functionality and aesthetic. Each New Ultimate EVO bar is built with a 31.8mm stem clamp design for increased strength and rigidity, resulting in fantastic ride characteristics. New Ultimate logos and tilt marks are applied to the surface for ease of alignment.
Designed for XC race use only. The New Ultimate EVO carbon mountain handlebar is no compatible with bar ends.
Tools required will depend on the stem, shifter, brake lever, and bar end models. Use of a torque wrench is strongly recommended, with a maximum torque rating of 9Nm.
