New Ultimate Disc Brake Rotor
 1 Remaining
$40.00  $30.00
Save: $10.00 off
Add to Cart:
Weight (without bolts) 80 grams
Bolt Pattern 6-bolt ISO
Diameter 160 mm
The material of choice for New Ultimate's disc brake rotors is durable and inexpensive steel. While this material is normally reserved for heavier workhorse rotors, the New Ultimate design approaches a weight close to expensive and short-lived titanium and composite alloy rotors. This low weight is achieved through aggressive machining, so that only the material that is structurally necessary remains. The resulting shape, with its organic, flowing lines, is quite pleasing.
Each rotor includes a set of 6 steel rotor bolts, pretreated with thread locker for security. Please note that this rotor is directional and must be installed with the logos facing outward. We recommend using a torque wrench for installation; the recommended torque is a standard 6.2 Nm.
