Neil Pryde Nazare
Neil Pryde Nazare
Neil Pryde Nazare
Neil Pryde Nazare
Neil Pryde Nazare
Neil Pryde Nazare
Frameset Weight940 grams (56 cm)
MaterialC6.9 Toray UD carbon
Bottom Bracket ShellPF 30
SeatpostNeil Pryde Aeroblade CF
Cable RoutingMechanical
Shimano Di2
Details
NeilPryde’s sizeable knowledge of carbon fiber manufacturing is widely respected due to decades in the watersports industry. Established in 1970 as a simple sail manufacturer for yachts in the European market, they quickly waded into the production of quality masts. Cultivating their knowledge of carbon fiber over years of mast production, and eventually wind surfing vessels that would go on to set multiple world records, NeilPryde has developed an aptitude for fine tuning carbon into wind cheating shapes. Relying on their wealth of knowledge and years of experience, as well as a partnership with BMW’s DesignworksUSA , NeilPryde is able to create a unique take on frame design. Capable of competing in every category against top level frame manufacturers, NeilPryde is quickly making a name for themselves in the peloton.
Introducing the frame that carried the UnitedHealthcare pro team to 90 podium finishes in 2013, the Nazaré. Designed as the perfect all around road frame that incorporates well thought out aerodynamics, and an expertly tuned carbon layup that results in excellent overall riding characteristics. Utilizing one piece chainstays/dropouts, the Nazaré requires less carbon at bonding points, saving weight, while eliminating unnecessary joints to produce a stiffer ride. Additionally by using pre-preg carbon fiber, NeilPryde is able to greatly reduce the necessary overlap in layers, saving even more weight. By incorporating wide tube profiles and specially designed Kamm-tails throughout the frame, the Nazaré retains torsional rigidity while effectively managing both turbulent and laminar air flow.
Available in 5 sizes ranging from 49 cm to 58 cm, the Nazaré makes dialing in your personal fit easy, while sacrificing zero of the performance you require.
