Misc/Specialty
Arundel boldly declares their Dual seat bag as the right size . We have to agree. This bag fits two standard road tubes, two CO2 cartridges, an...
$19.006 options.View
Arundel's Tubi bag is specifically sized to fit a spare tubular tire. Alternatively, the Tubi provides ample room for those riders who enjoy a...
$19.0014 in stock.View
Assos Chamois Creme is formulated for use with synthetic and "natural" chamois, designed for all cycling shorts. Composed with 100% natural...
$20.002 in stock.View
Beljum Budder is a premium quality, paraben-free skin lubricant designed for cyclists, runners, hikers, or any activity in which friction and chafing...
$18.002 in stock.View
Take an intimate look behind the scenes of Cycle Passion's 2011 calendar photo shoot with the DVD documentary Eyes Wide Open . This professionally...
$25.002 options.View
The 2012 Cyclepassion Calendar is now in stock. Fairwheel bikes is quite please to bring you the Cycle Passion Calendar. The 2008 edition speaks for...
$45.000 in stock.View
The 2012 Cyclepassion Calendar is now in stock. Fairwheel Bikes is pleased to bring you the 2009 Cycle Passions calendar. The 2009 edition features...
$45.007 in stock.View
The 2012 Cyclepassion Calendar is now in stock. Fairwheel Bikes is pleased to bring you the 2010 Cycle Passion calendar. The 2010 edition features...
$50.0010 in stock.View
The 2012 Cyclepassion Calendar is now in stock. The 2011 edition of the CyclePassion 12-month calendar again displays some of the top female...
$50.000 in stock.View
Featured Riders Veronica AndreassonSweden Pauline Ferrand PrevotFrance Liz HatchUSA Hanna Klein Germany Katherine O`SheaAustralia Marion...
The 2011 edition of the CyclePassion 12-month calendar for a first time available in a smaller desktop version. The 2011 displays some of the top...
$35.000 in stock.View
The design of Extralite hubs requires the use of an additive-free, lightweight synthetic grease in order to protect and lubricate the internal o-ring...
$12.005 in stock.View
These standard-issue pint glasses bear the official Fair Wheel Bikes logo, along with a subtle declaration of our long history in the bicycle...
$10.009 in stock.View
Package of 25 cable end caps. Black, Blue, Gold, Green, Purple and Red. Fits either brake or shift cables.
$7.006 options.View
Specifications Weight w/ Bolt and Spacer 5.6 grams Compatibility braze-on derailleur tabs only Material 7075 aluminum Detail A...
$28.004 options.View
Specifications Weight 1.7 grams each Housing Compatibility 4 mm, 5mm Available Colors black, blue, celeste, red, white, yellow Detail These...
$8.007 options.View
This carbon preload cap from Fibre-Lyte is designed for THM's Clavicula Crankset. This cap features a 1k carbon weave finish. Does not include fixing...
$20.003 in stock.View
Specifications Weight 2.5 grams/set Material 7075 aluminum Details KCNC's lightweight bottle cage bolts are made from 7075 aluminum, and are...
$10.006 options.View
Specifications Weight15 grams per pair CompatibilityXTR M-980-I, XT M-780-I Clamp Material7075 aluminum Bolt Materialtitanium Detail I-Spec is...
$30.005 options.View
Specifications Weight23 grams Material7075 aluminum CompatibilityShimano, KCNC cranksets Detail KCNC' mountain chain catcher is designed to deflect...
$34.005 options.View
Specifications Material7075 Alloy Weight1.2 grams per pair FitsPresta Valves ColorsBlack, Blue, Gold, Green, Red, Silver Detail Anodized Kcnc...
$6.506 options.View
Specifications Valve compatibility Presta only Detail KCNC's pump head provides a great aftermarket upgrade option for the most common...
$40.000 in stock.View
Specifications Weight w/ Hardware19 grams Material7075 aluminum Bolt Materialstainless steel Compatibilitybraze-on derailleurs Detail KCNC's chain...
$32.006 options.View
Specifications Weight4.5 grams Threadm30 x 8 Material6061 aluminum ColorsBlack, Blue, Gold, Green, Red, Silver CompatibilityShimano Hollowtech II,...
$8.006 options.View
Specifications Weight, 50 mm2.2 grams each Weight, 85 mm4.2 grams each Valve CompatibilityPresta Detail KCNC's lightweight valve extenders are a...
$12.007 options.View
Specifications Material7075 Alloy FitsXTR M980 ColorsBlack, Gold, Red Detail With the growing popularity of double chainrings, lots of people are...
$30.003 options.View
Rox Ultralite rim strips are manufactured from lightweight puncture-resistant nylon with a super sticky adhesive backing. The lightest rim strip on...
$13.004 in stock.View
The staff here at Fair Wheel Bikes would like to think we know a thing or two about the sun's rays. Most of us picked this locale of southern Arizona...
$7.004 options.View
Specifications Size Max Torque Weight M4 x 160.8 Nm0.5 grams M5 x 201.5 Nm0.7 grams M6 x 304.0 Nm1.3 grams M6 x 164.0 Nm0.7 grams Detail...
$20.005 options.View
Disc wheel pump adapter. Features a threaded end that easily attaches to the Schrader port of most pumps. It can also just be inserted into the hose...
$15.950 in stock.View
Detail Swiss Stop's Disc Brake Silencer is a metallic based aerosol spray treatment designed for both metallic and organic disc brake pads. True to...
$32.004 in stock.View
Detail Many cyclists have experienced the frustration of a slipped seatpost or handlebar, and more than a few have endured the anguish of a cracked...
$20.002 options.View
Tune's 0.3 gram Pulsar spoke magnet is manufactured from a highly magnetic rare earth metal. Using such material allows the magnet to be made...
$8.000 in stock.View
Tune's carbon fiber shifter clamp bands, manufactured in Germany by Bicycle Tuning Parts, are the ultimate weight tuning part. Invisible under the...
$70.000 in stock.View
Veloflyte Carbon Nameplates offer a new way to accessorize your Shimano STI's. 100% carbon construction and just 2g, these little pieces will add a...
$35.004 options.View
