Mcfk Vorbau Carbon Stem
Sign Up For Our Newsletter
You're Signed Up!
Material, StemCarbon
Material, Faceplate7075 Txx aluminum
Material, HardwareTi6Al4V titanium
Stem Angle+/- 6°
+/- 17 °
Clamp Diameter31.8
Steerer Clamp Diameter1-1/8"
Recommended UseMTB, Cyclocross, Road
Rider Weight Limit85 kg
Weights, 3K
90 mm80 grams
100 mm83 grams
110 mm83 grams
UD finish + 3-5 grams
Product Manuals
Mcfk Stem
Mcfk Vorbau Carbon Stem 6 deg, 80 mm, 3k gloss $400.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 6 deg, 80 mm, UD Matte $450.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 6 deg, 90 mm, 3k Matte $450.00  1 Remaining
Mcfk Vorbau Carbon Stem 6 deg, 90 mm, 3k gloss $400.00  1 Remaining
Mcfk Vorbau Carbon Stem 6 deg, 90 mm, UD Matte $450.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 6 deg, 100 mm, 3k Matte $450.00  1 Remaining
Mcfk Vorbau Carbon Stem 6 deg, 100 mm, 3k Gloss $400.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 6 deg, 100 mm, UD Matte $450.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 6 deg, 110 mm, 3k Matte $450.00  1 Remaining
Mcfk Vorbau Carbon Stem 6 deg, 110 mm, 3k Gloss $400.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 6 deg, 110 mm, UD Matte $450.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 17 deg, 100 mm, 3k Matte $450.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 17 deg, 100 mm, UD Matte $450.00 Notify Me When Available
Mcfk Vorbau Carbon Stem 17 deg, 110 mm, 3k Matte $450.00  1 Remaining
Mcfk Vorbau Carbon Stem 17 deg, 110 mm, UD Matte $450.00 Notify Me When Available
Details
Germany based carbon fiber masterminds, MCFK have produced a plethora of gorgeous cycling components over the years that border on fine art. Maintaining the level of rideable art, may we present the Vorbau. A stem 100% constructed in Germany that required an immense amount of research and testing before MCFK was satisfied. Rigidity is an inherent characteristic of components manufactured from carbon fiber, however in an effort to further reduce flex between the handlebar and steer tube, MCFK chose to utilize a 270 ° handlebar clamp. When the handlebar clamp wraps around more of the bar, force from the faceplate during tightening is better displaced over a larger area, as well as flexural stress from the handlebar is displaced over a larger surface, ultimately resulting in less movement in the cockpit. By taking advantage of Ti6Al4V titanium hardware, as well as a 7075 T6 aluminum faceplate, MCFK was further able to reduce weight, and increase rigidity where it counts.
Please carefully follow the given torque specs for the MCFK Vorbau and use a torque wrench. The steer tube clamp hardware is rated at 5 Nm, while the faceplate hardware is rated at 3 Nm. The use of Tacx carbon assembly paste is highly recommended.
