Mcfk Road Handlebar
$421.00
Germany-based MCFK has been making a name for themselves producing high quality handmade carbon components. Their first handlebar uses the 31.8mm diameter compatible with most modern stems. Many co-molded pieces of UD, 1k and 3k carbon fiber are a masterfully crafted into a comfortable ergonomic shape. The tops feature several degrees of backsweep for relief on the wrists. A channel on the underside routes the cables cleanly and maintains a comfortable round profile under the tape. The transition out to the hoods is very flat to allow a long perch with many comfortable positions. The drops are relatively shallow at 130mm with a long graceful curve that flares out a few degrees. These bars are very stiff with a 100kg weight limit. Please use a calibrated torque wrench and follow the manufacturer's guidelines for maximum torque settings.
Weight185g
MaterialCarbon
Width (C - C at levers)42 cm
Width (C - C)47 cm
Reach77 mm
Drop130 mm
Clamp Diameter31.8
Top Diameter31.8 mm -> 27.5 mm
Drop Diameter24.0 mm
Back Sweep5 degrees
Max Torque4 Nm
