MCFK Road Handlebar
MCFK Road Handlebar 42 cm, UD Gloss $550.00 Notify Me When Available
MCFK Road Handlebar 42 cm, UD Matte $550.00 In Stock
MCFK Road Handlebar 44 cm, UD Matte $550.00  1 Remaining
Description
Germany-based MCFK has been making a name for themselves producing high quality handmade carbon components. Their first handlebar uses the 31.8mm diameter compatible with most modern stems. Many co-molded pieces of UD, 1k and 3k carbon fiber are a masterfully crafted into a comfortable ergonomic shape. The tops feature several degrees of backsweep for relief on the wrists. A channel on the underside routes the cables cleanly and maintains a comfortable round profile under the tape. The transition out to the hoods is very flat to allow a long perch with many comfortable positions. The drops are relatively shallow at 130mm with a long graceful curve that flares out a few degrees. These bars are very stiff with a 100kg weight limit. Please use a calibrated torque wrench and follow the manufacturer's guidelines for maximum torque settings.
Material Carbon
Finish 3K Gloss
Weight 165g (42 cm)
Width (C-C at levers) 42cm
Width (C-C) (47 cm)
Reach 77 mm
Drop 130 mm
Clamp 31.8 mm
Max Torque 4 Nm
Diameter (Tops) 31.8 mm -> 27.5 mm
Diameter (Drops) 24.0 mm
Back Sweep
Comment on MCFK Road Handlebar
