Mcfk
Mcfk Carbon Fiber ISP Seatpost
Specifications Weight 80 grams Available Diameters 30.2, 34.9, 38.2 mm Adj Range 30 mm Tube Material Carbon Fiber Bolt Material 6-4...
$250.00
6 options.View
Mcfk Carbon Saddle
Specifications Weight72 gramsConstructionfull carbon fiberWidth120 mmLength255 mmRail Diameter7x9 mm ovalUseroad, cross country, cyclocrossRider...
$350.00
0 in stock.View
Mcfk Carbon Seatpost
Specifications Weight 100-107gr Available Diameters 27.2, 30.9, 31.6 mm Available Lengths 250, 300, 350 Tube Material Carbon UD, 1k, 3k ...
$350.00
6 options.View
Mcfk Carbon Seatpost Collar
Specifications Weights31.8 - 7.6 grams, 34.9 - 8.5 gramsCollarCarbon FiberBoltCNC TitaniumTorque spec6 Nm maximum Detail The Mcfk seatpost collar...
$80.00
4 options.View
Mcfk Carbon Setback Seatpost
Specifications Weight, 27.2 x 300107 gramsWeight, 27.2 x 350113 gramsWeight, 31.6 x 300112 gramsWeight, 31.6 x 350119 gramsSetback20 mmBolt...
$490.00
6 options.View
Mcfk Front Derailleur Clamp
Specifications Weight ~6 grams Material Carbon Fiber Body, Titanium screw Max Torque 6Nm Details Mcfk's carbon fiber front derailleur clamp is...
$80.00
1 options.View
