Mcfk Carbon Seatpost
Mcfk Carbon Seatpost 300 x 31.6, 1k$350.00 Notify Me When Available
Mcfk Carbon Seatpost 300 x 31.6, 3k$350.00 In Stock
Mcfk Carbon Seatpost 300 x 31.6, UD$350.00  1 Remaining
Mcfk Carbon Seatpost 350 x 31.6, 1k$350.00 Notify Me When Available
Mcfk Carbon Seatpost 350 x 31.6, 3k$350.00  1 Remaining
Mcfk Carbon Seatpost 350 x 31.6, UD$350.00  2 Remaining
Weight 100-107gr
Available Diameters 27.2, 30.9, 31.6 mm
Available Lengths 250, 300, 350
Tube Material Carbon UD, 1k, 3k
Bolt Material 6-4 titanium M5
Yoke Material 7075 Aluminum
Use Road or Mtb
Rider Weight Limit 85 kg (185 lbs)
Handmade in Germany with not only an amazing low weight but with one of the best looking finishes of all super light posts. Mcfk seatposts are given a specific insertion range for each given size. Measured from top of seat tube to saddle rails, the insertion ranges are:
  • 300: 160-210 mm
  • 350: 205-265 mm
Available in 3 finishes, UD, 1k and 3k.
M5 Titanium bolts with alloy yokes and reinforced carbon fiber half pipe.
Mcfk posts cannot be cut or shortened and may be clamped only in the reinforced clamping zone.Torque specs, 5nm max for saddle rails and 6nm max for seat collar. Tacx carbon assembly paste is strongly recommended.
Comment on Mcfk Carbon Seatpost
