Mcfk Carbon Flat Mountain Handlebar
With their first mountain bike handlebar, MCFK accomplishes an impressively strong lightweight carbon bar. Intricately produced with a particularly asymmetric layering structure, MCFK is able to achieve a high stability handlebar rated up to 90 kilos. Along with durability and agility, these handlebars are also notably stiff due to the oversized 31.8mm clamp diameter. Available in both unidirectional and 3K gloss finishes.
As with all carbon components we recommend the use of a carbon prep such as Tacx's Dynamic compound on any carbon friction fit. When installing the handle bar make sure to use a torque wrench to follow all torque specifications. The face plate should be tightened to no more than 4Nm and any shifter or brake lever no more than 2.5Nm. The MCFK bars we've stocked are not meant to be used with any bar ends.
MaterialCarbon Fiber
Finishes3K Gloss, UD
Clamp Diameter31.8
Widths700mm, 640mm, 580mm
Sweep6 degree
RiseLow Rise: 15mm
Flat: 0mm
Weight Limit90kg (195 lbs)
Torque SpecsFaceplate: 4Nm
Shifter / Brake Levers: 2.5Nm
Flat 3K700mm - 125g
680mm - 106g
640mm - 102g
580mm - 103g
Flat UD700mm - 130g
640mm - 122g
