Lightning Carbon Mountain Crankset
$530.00
SKU:
3130
Lightning Cycle Dynamics' carbon crankset breaks new ground by taking the best aspects of modern crank design and combining them into a complete, highly customizable package. Using a 30mm spindle and hollow, high-pressure molded carbon arms, Lightning has achieved just about the lightest weight possible while making no compromise in strength or stiffness. The cranks are finished in an attractive 3k carbon weave with stealthy black anodized cups, spindle, spider, and preload adjuster.
Lightning cranksets are manufactured in California, USA.
Ordering
The modular nature of the Lightning crankset, combined with its low volume production, allows for a multitude of custom options. Any option not listed for purchase here can be special ordered; please contact us for more information. The crank arms can be manufactured in twelve lengths, from 160 to 190 mm. Four bottom bracket options allow for compatibility with nearly all modern framesets, with ceramic bearings available as an option. Lightning's interchangeable spiders are available in two options; a 94 BCD double chainring spider, and a reversible 104/64 BCD spider. This reversible spider is compatible with either triple or double chainring setups, depending on its orientation. If a different chainring combination is desired all Lightning spiders are compatible with all Lightning cranks so mix and match without fear. Aftermarket rings are also available from several different manufacturers in various tooth configurations and styles.
The required installation tools (a 6 mm hex 1/2" ratchet extension and rubber grip pad) and detailed installation instructions are included.
Wolf Tooth Components Chainring
The Wolf Tooth Components Drop-Stop Chainring is crafted to seamlessly integrate with your 1X Lightning crank setup. By utilizing uniquely machined teeth designed to perfectly mesh with the male and female links in your chain, the Drop-Stop chainring minimizes the possibility of chain suck and drop.
Carbon-Ti X-MonoSync Chainring
Available in a variety of tooth counts these ultralight Narrow-Wide chainrings provide a superbly durable option for those looking to maintain a sleek minimalist look. Crafted from "Grade 5" Titanium these chainrings will far outlast their aluminum bretheren. Featuring the ingenious narrow-wide tooth profile these ring nearly eliminate the possibility of a dropped chain even over the roughest of terrain.
Bottom Bracket CompatibilityBSA, BB30, PF30, BB92
Chainring Compatibility64/104 Triple, 64/104 Double, 94 Double, 104 Single, XX1, Wolf Tooth Components
Crankarm Materialhollow carbon fiber
Spindle Material7075-T6 aluminum, hard anodized
Spindle Diameter30 mm
Center BoltM14, 6/4 titanium
Weight Limit, Standard220 lbs
Weight Limit, Clydesdale280 lbs
Weight
Crankarms40 grams
XX1 Spider27 grams
104/64 Spider34 grams
BSA BB82 grams
PF30 BB83 grams
BB92 BB40 grams
