Lightning Carbon Cranks
Lightning Carbon Cranks 165 Compact$670.00 Notify Me When Available
Lightning Carbon Cranks 165 Standard$670.00 Notify Me When Available
Lightning Carbon Cranks 170 Compact$670.00  1 Remaining
Lightning Carbon Cranks 172.5 Compact$670.00 Notify Me When Available
Lightning Carbon Cranks 172.5 Standard$670.00  1 Remaining
Lightning Carbon Cranks 177.5 Compact (no logo)$670.00  1 Remaining
The long awaited crank from Lightning has finally seen the light of day. Often copied, replicated and licensed, Lightning's revolutionary crank is now available for threaded bottom brackets. The crank features carbon arms with an aluminum spider, joined in the center by a Hirst Joint (ala Campagnolo). The bottom bracket cups are secured by a genius knurled design to aid in the threading process, no superfluous installation tool required. Lightning claims a q-factor of 149mm, however the pedal threads 2.5mm into the arm on either side, reducing the q-factor to a scant 144mm. Weight for a 172.5mm SL set is 445g including BB. Clydesdale sets are also available. Ceramic bearing upgrades are also available
220lb. Rider weight limit on the standard.
280lb. Rider weight limit on the Clydesdale.
Available in 110 compact or 130 standard BCD.
Lengths: 160, 162.5, 167.5, 170, 172.5, 175, 177.5, 180, 185, 190mm
Compatible with Quarq CinQo power meter.
Comment on Lightning Carbon Cranks
