Lezyne Pressure Drive
Lezyne Pressure Drive M Blue$40.00 Notify Me When Available
Lezyne Pressure Drive S - Blue$40.00 Notify Me When Available
Lezyne Pressure Drive S - Gold$40.00 Notify Me When Available
Lezyne Pressure Drive S - Red$40.00 Notify Me When Available
Lezyne Pressure Drive S - Carbon$80.00 Notify Me When Available
Lezyne Pressure Drive M - Carbon$80.00 Notify Me When Available
Some of Lezyne's most exciting offerings are their line of frame and floor pumps. The attention to detail, level of refinement, utility, and finish are unmatched.
The Pressure Drive falls under the high-pressure category of the Lezyne hand pumps, but is also usable for inflating larger volume tires.
Lezyne claims the Pressure Drive is able to inflate a tire up to 120psi. We always try to verify the claims of manufacturers, so without further delay our humble test results:
700x23 inflation to 90psi: 2 minutes
Max Pressure able to achieve in 3 minutes: 100psi
That's not quite 120psi, but 100psi out of a hand pump is pretty good, and leaves us confident that this pump is suitable to inflate a flat tire on the road.
One of the great features of the Lezyne hand pumps are the rubber hoses which thread in to the valve, and to the pump body. The flexible rubber hose allows for the pump to move during inflating without fear of ripping the valve stem out - a problem with most hand and frame pumps.
The Pressure Drive is available in "S" and "M" sizes. They're the same price, and just a bit different. The "S" is the smallest size, and sacrifices a bit of usability, in favor of its smaller dimensions. The "M" is larger, but is easier to use.
The pump comes with a plastic bracket and phillips-head bolts so that it may be attached to your frame underneath the bottle cage.
Presta and Schrader compatible
Weight: 90g (S - Alloy), 94g (M - Carbon)
