Lezyne
Lezyne Alloy Floor Drive
CNC machined aluminum barrel and foot; steel piston Varnished wood handle with CNC machined aluminum center lug Alloy Flip-Thread chuck threads...
$69.00
2 options.View
Lezyne Carbon 10 multi-tool
The Lezyne Carbon 10 multi-tool features the most commonly used bike related tools, held together with carbon side plates and titanium hardware. The...
$99.00
0 in stock.View
Lezyne Carbon 5 multi-tool
The Carbon 5 is the lightest bare bones multi-tool available, featuring carbon fiber side plates, and titanium hardware. It includes 3, 4, 5, and 6mm...
$80.00
2 in stock.View
Lezyne Classic Chain Whip
The varnished wood handle of Lezyne’s Classic Chain Rod makes for a chain whip that is a pleasure to use. The craftsmanship of this tool makes it...
$28.00
2 in stock.View
Lezyne Classic Pedal Wrench
The Classic Pedal Rod’s shaped and varnished wood handle makes for a pedal wrench that is a pleasure to use. As with the rest of Lezyne’s product...
$24.00
2 in stock.View
Lezyne CNC Chain Whip
A showpiece in and of itself, Lezyne designed the CNC Chain Rod to be indestructible. The 100% CNC-machined aluminum handle, connected to the...
$40.00
2 in stock.View
Lezyne CNC Floor Drive
All parts are custom, CNC machined aluminum100% aluminum Flip-Thread chuck threads securely to both Presta and Schrader valvesFlip-Thread chuck and...
$99.00
2 options.View
Lezyne CNC Pedal Wrench
Lezyne’s CNC Pedal Rod is the last pedal wrench you’ll ever buy. In a world of increasingly ephemeral products, this pedal wrench, with a handle...
$35.00
2 in stock.View
Lezyne Road Drive
The Lezyne Road Drive is the premier pump for inflating your road tires with a hand-pump. It's rated to inflate up 160psi, but unless you've got...
$45.00
4 options.View
Lezyne Stainless 20 multi-tool
The Lezyne Stainless 20 is the holy-grail of bicycle multi-tools. Short of riding with a portable work-bench, the Stainless 20 is your best bet. It...
$50.00
1 in stock.View
Lezyne Steel Floor Drive
Alloy foot, steel barrel and piston Varnished wood handle 47”/120cm extra-long, premium-grade hose Presta/Schrader compatible head Long travel...
$49.00
2 options.View
Lezyne V10 multi-tool
The Lezyne V10 packs a lot of utility in to a relatively small form factor. Instead of using the traditional wrapping bit around an axle style most...
$36.00
0 in stock.View
Lezyne V5 multi-tool
The Lezyne V5 is so small, you can't afford not to carry it. It features a minimal set of bits, which are responsible for 90% of adjustments on your...
$17.50
0 in stock.View
