KMC X10SL 10 Speed Chain
KMC X10SL 10 Speed Chain Black DLC$130.00 In Stock
KMC X10SL 10 Speed Chain Gold / Black$130.00 In Stock
KMC X10SL 10 Speed Chain Gold TiN$85.00 In Stock
KMC X10SL 10 Speed Chain Pink Lady$85.00  2 Remaining
KMC X10SL 10 Speed Chain Red DLC$130.00 In Stock
KMC X10SL 10 Speed Chain Silver$80.00 In Stock
Weight, 116 links250 grams
Dimensions1/2" x 11/128"
Use10 speed Campagnolo, Shimano, Sram
KMC's X10SL chain is the all-around best-performing, lightest chain available today. The X10SL is the result of 3 years of development and testing by KMC, in which they radically rethought the chain production process to produce a product unmatched in lightness and strength. In testing, this chain was put through the wringers by cyclists of all disciplines, from road racing to mountain downhill and exceeded all expectations.
The X10SL features hollow inner and outer plates and hollow pins. The pins are riveted using KMC's "Lat Step" process, which seals the outer plates with a massive 350 kilograms of force, making it the strongest chain connection in the industry today. The chain's outer plates are shaped with KMC's X-bridge design, which allows for smoother, more precise shifts. High-precision manufacturing tolerances, along with a proprietary X-SP friction-reducing treatment extends chain life.
Pink Lady - These special colored chains feature pink powder-coat on the chain's pins and inner plates. Additionally, KMC is donating 15% of the sales from these chains to the Pink Ribbon Foundation.
Gold (TiN) - Beyond their bold appearance, KMC's Titanium Nitride coated chains are less susceptible to dirt intrusion, easier to clean, and last longer than standard chains.
Gold / Black - These World Tour Limited Edition Vacansoleil/DCM chains feature KMC's TiN treatment with additional aesthetic black coating on the pins and inner plates. This chain is packaged in a handsome gift box.
DLC - These chains feature a super hard and highly wear resistant diamond like coating. Available in stealth black, or with red powdercoated pins and inner plates for extra style points.
We highly recommend this chain for its superior shifting performance and long life. Additionally, it is suitable for both Campagnolo and Shimano systems, and will perform better than the manufacturers' chains. Each X10SL chain includes an 10-speed Missing Link for easy, tool-free chain removal and reassembly.
KMC X10SL Features
Light Weight
Hollow Pin
XX StretchProof Treatmentexceptional durability
Double X Bridge Outer Platesimproved shift performance
Chamfered Outer Platesimproved shift performance
Inner Plate Chamferingimproved chain articulation
Mushroomed RivetingHigh Pin Strength
Bushing-less Constructionsmooth power transmission
Noiseless Functionnoise reduction
Comment on KMC X10SL 10 Speed Chain
