KMC
KMC Chain Master Link Tool
Detail KMC's MissingLink chain master link tools are specifically designed for use with KMC chains, but they will work well with most other...
$15.00
2 options.View
KMC Chain Tool
$180.00
0 in stock.View
KMC Digital Chain Checker
Specifications Chain Compatibility8, 9, 10, 11 speed and single speed BatteryLR44 1.5V Body Materialhardened stainless steel Accuracy0.01mm (.0005...
$85.00
0 in stock.View
KMC DX10SC 10 Speed Chain
Specifications Dimensions1/2" x 11/128" ColorSilver/Gray Weight269gr. (112 links) CompatibilityShimano/SRAM/Campagnolo 10 speed drive Detail The...
$40.00
4 in stock.View
KMC Missing Link
Details As far as master links go, the KMC Missing Link is on the top of our list. The Missing Link's function is simple, consisting of two...
$5.00
3 options.View
KMC X10.93 10 Speed Chain
Specifications Dimensions1/2" x 11/128" ColorSilver/Gray Weight268gr. (112 links) CompatibilityShimano/SRAM/Campagnolo 10 speed drive Detail KMC's...
$45.00
5 in stock.View
KMC X10SL 10 Speed Chain
Specifications Weight, 112 links250 grams Dimensions1/2" x 11/128" Use10 speed Campagnolo, Shimano, Sram Detail KMC's X10SL chain is the all-around...
$80.00
6 options.View
KMC X11SL 11 Speed Chain
Specifications Weight, 112 links229 grams Useroad, Campagnolo 11 Speed Detail KMC has utilized the technology developed with their super...
$95.00
2 options.View
KMC X9.93 9 Speed Chain
Specifications Dimensions1/2" x 11/128" 116 links ColorSilver/Gray Weight293gr. Compatibility9 speed drive Detail KMC's X9 series chains are the...
$22.00
9 in stock.View
KMC X9SL 9 Speed Chain
Specifications Dimensions1/2" x 11/128" 116 links ColorSilver/Gray Weight265gr. Compatibility9 speed drive Detail KMC's X9SL chain is the...
$70.00
14 in stock.View
KMC X9SL 9 Speed Gold Chain
Specifications Dimensions1/2" x 11/128" 116 links ColorGold TiN Weight265gr. Compatibility9 speed drive Detail KMC's X9SL chain is the all-around...
$75.00
11 in stock.View
