KinLin XR-300 Clincher Rim
KinLin XR-300 Clincher Rim 16 Hole Black$60.00 Notify Me When Available
KinLin XR-300 Clincher Rim 18 Hole Black$60.00 Notify Me When Available
KinLin XR-300 Clincher Rim 20 Hole Black$60.00 In Stock
KinLin XR-300 Clincher Rim 20 Hole Red$60.00  1 Remaining
KinLin XR-300 Clincher Rim 20 Hole Silver$60.00 Notify Me When Available
KinLin XR-300 Clincher Rim 20 Hole White$65.00 In Stock
KinLin XR-300 Clincher Rim 24 Hole Black$60.00 In Stock
KinLin XR-300 Clincher Rim 24 Hole Red$60.00 Notify Me When Available
KinLin XR-300 Clincher Rim 24 Hole Silver$60.00  1 Remaining
KinLin XR-300 Clincher Rim 24 Hole White$65.00 In Stock
KinLin XR-300 Clincher Rim 28 Hole Black$60.00 Notify Me When Available
KinLin XR-300 Clincher Rim 28 Hole Silver$60.00 Notify Me When Available
KinLin XR-300 Clincher Rim 28 Hole White$65.00 In Stock
KinLin XR-300 Clincher Rim 32 Hole Black$60.00 In Stock
KinLin XR-300 Clincher Rim 32 Hole Silver$60.00 Notify Me When Available
Weight 455 grams
Depth 30 mm
Sidewall Width 19 mm
Tire Compatibility 700c clincher
Available Drillings 16, 20, 24, 28, 32
Available Colors black, blue, gold, red, silver, white
ERD 577 mm
The KinLin XR-300 is our favorite aluminum rim for a variety of applications. These rims feature a 30mm aerodynamic cross section and a weight most competitors can't match at half the depth. An added bonus of the deep cross section is strength, making the XR-300 well suited for stronger, heavier riders, or applications where total wheel stiffness is an important consideration. The XR-300 has developed an impressive reputation within the cycling community for combining excellent ride quality and durability.
Kinlin rims are extruded from a super light Niobium-Aluminum alloy and joined with a high quality pinned joint. Finish work includes a high gloss anodization and machined sidewalls.
The XR-300 rim is also available as a wheelset built with DT Swiss hubs and DT Swiss Aerolite spokes.
Assembly
While we recommend that bicycle wheels be built by an experienced professional, the relative low cost of KinLin rims make them ideal for first time or novice wheelbuilders. We are happy to provide helpful advice in hub and spoke selections, or complete wheel build service. For inquires, please contact us directly or submit a form for a custom wheelbuild here.
Comment on KinLin XR-300 Clincher Rim
