KinLin XR-200 Clincher Rim
KinLin XR-200 Clincher Rim 20 Hole, Black$55.00 In Stock
KinLin XR-200 Clincher Rim 24 Hole, Black$55.00 In Stock
KinLin XR-200 Clincher Rim 28 Hole, Black$55.00  2 Remaining
KinLin XR-200 Clincher Rim 28 Hole, Silver$55.00 Notify Me When Available
KinLin XR-200 Clincher Rim 32 Hole, Black$55.00 In Stock
KinLin XR-200 Clincher Rim 32 Hole, Silver$55.00 Notify Me When Available
Weight390 grams
Width19 mm
Depth22 mm
Available Drillings20, 24, 28, 32 hole
Available Colorssilver, black
Tire Compatibility700c clincher
ERD594 mm
The XR-200 is KinLin company's lightest road rim, and one of the lightest aluminum rims on the market. The XR-200 features a box-shaped cross section for added strength - not the most aerodynamic rim on the market, but ideal for use in a climbing or weight-conscious wheelset. The XR-200 is extruded from a superlight Niobium-Aluminum alloy and joined with a high quality pinned joint. Finish work on these rims includes a high gloss anodization and machined sidewalls. For these rims, we do recommend higher spoke counts (e.g. 24 front, 28 rear) for riders over 55kg (120 lbs), and do not recommend them at all for riders over 85kg (190 lbs).
Assembly
While we recommend that bicycle wheels be built by an experienced professional, the relative low cost of Kinlin rims make them ideal for first time or novice wheelbuilders. We are happy to provide helpful advice in hub and spoke selections, or complete wheel build service. For inquires, please contact us directly or submit a form for a custom wheelbuild here.
