KinLin XR-19W Clincher Rim
KinLin XR-19W Clincher Rim 20 Hole$65.00 In Stock
KinLin XR-19W Clincher Rim 24 Hole$65.00 In Stock
KinLin XR-19W Clincher Rim 28 Hole$65.00 In Stock
Weight410 grams
Width20 mm
Depth21 mm
Available Drillings20, 24, 28 hole
Tire Compatibility700c clincher (ISO 622)
ERD598 mm
Kinlin's XR-19w is a lightweight yet sturdy rim whose ideal application may vary between inexpensive climbing wheelsets and high mileage training wheels. These niobium alloy rims are equipped with single eyelets for easier assembly and service. The rim surface is polished and black anodized with high qualily machined sidewalls. Kinlin rims feature high strength sleeved joints.
Assembly
While we recommend that bicycle wheels be built by an experienced professional, the relative low cost of Kinlin rims make them ideal for first time or novice wheelbuilders. We are happy to provide helpful advice in hub and spoke selections, or complete wheel build service. For inquires, please contact us directly or submit a form for a custom wheelbuild here.
The maximum recommended spoke tension for XR-19w rims is 105 kgf.
Comment on KinLin XR-19W Clincher Rim
