KinLin XC-279 Clincher Rim
XR-279 Rim Specifications
Weight 490 grams
Depth 28 mm
Width Outer: 23 mm
Inner: 17.2 mm
Tire Compatibility 700c clincher
Available Drillings 20, 24, 28, 32
Available Colors black
ERD 584 mm
KinLin XC-279 Clincher Rim 20 Hole, Black $60.00 In Stock
KinLin XC-279 Clincher Rim 24 Hole, Black $60.00  1 Remaining
KinLin XC-279 Clincher Rim 28 Hole, Black $60.00 In Stock
Details
KinLin's new XC-279 rim is a wider version of their XR-270 with a rounder section. The width has been brought up 4mm, from 19mm to 23mm at the brake track. The profile is rounded at the nipples making it more comparable to HED's Belgium in shape. The profile is 1mm taller as well. The rim is, like all KinLin rims, extruded from a superlight Niobium-Aluminum alloy and joined with a high quality pinned joint. Finish work on these rims includes glossy anodization and machined sidewalls.
Wheel Building
While we recommend that bicycle wheels be built by an experienced professional, the relative low cost of KinLin rims make them ideal for first time or novice wheel builders. We are happy to provide helpful advice in hub and spoke selections, or complete wheel build service. For inquires, please contact us directly or submit a form for a custom wheelbuild here .
Comment on KinLin XC-279 Clincher Rim
