KinLin TB-25 Tubular Rim
KinLin TB-25 Tubular Rim 20 Hole$60.00 In Stock
KinLin TB-25 Tubular Rim 24 Hole$60.00 In Stock
KinLin TB-25 Tubular Rim 28 Hole$60.00 In Stock
KinLin TB-25 Tubular Rim 32 Hole$60.00 In Stock
Weight440 grams
Width18.5 mm
Depth25.0 mm
Available Drillings20, 24, 28, 32 hole
Available Colorsblack
Tire Compatibility28" tubular
ERD592 mm
The TB-25 is KinLin company's tubular road rim, for use with 28" glued tubular tires only. While not especially lighter than KinLin's clincher rims, 100% of the rim material is structurally supportive, yielding a tough and aerodynamic cross section. These rims are ideal for use where budget is a concern and the superior ride quality of tubular tires is desired. Extruded from a superlight Niobium-Aluminum alloy and joined with a high quality pinned joint. Finish work on these rims include black anodization and machined sidewalls.
Assembly
While we recommend that bicycle wheels be built by an experienced professional, the relative low cost of Kinlin rims makes them ideal for first time or novice wheelbuilders. We are happy to provide helpful advice in hub and spoke selections, or complete wheel build service. For inquires, please contact us directly or submit a form for a custom wheelbuild here.
Comment on KinLin TB-25 Tubular Rim
