KinLin
Specifications Weight440 grams Width18.5 mm Depth25.0 mm Available Drillings20, 24, 28, 32 hole Available Colorsblack Tire Compatibility28" tubular...
$60.004 options.View
Specifications Weight, black430 grams Weight, white450 grams Width24 mm Depth20 mm Usecross country, disc only ERD539 mm Detail The XD-230 rim...
$55.00 $44.00Save: $11.00 off
2 options.View
Specifications Weight, black495 grams Weight, white520 grams Width24 mm Depth20 mm Usecross country, disc only ERD602 mm Detail The XD-230 rim...
2 options.View
Specifications Weight410 grams Width20 mm Depth21 mm Available Drillings20, 24, 28 hole Tire Compatibility700c clincher (ISO 622) ERD598 mm Detail...
$65.003 options.View
Specifications Weight390 grams Width19 mm Depth22 mm Available Drillings20, 24, 28, 32 hole Available Colorssilver, black Tire Compatibility700c...
$55.006 options.View
Specifications Weight445 grams Depth27 mm Sidewall Width19 mm Tire Compatibility700c clincher Available Drillings20, 24, 28, 32 Available...
$55.0011 options.View
Specifications Weight 455 grams Depth 30 mm Sidewall Width 19 mm Tire Compatibility 700c clincher Available Drillings 16, 20, 24, 28, 32 ...
$60.0015 options.View
Specifications Weight550 grams Depth38 mm Width20 mm ERD563 Detail The XR-380 has the deepest section in KinLin's rim line, and is one of the...
$120.004 options.View
