KCNC XTR Double Chainring Conversion
KCNC XTR Double Chainring Conversion Black$30.00 In Stock
KCNC XTR Double Chainring Conversion Gold$30.00  1 Remaining
KCNC XTR Double Chainring Conversion Red$30.00 In Stock
Material7075 Alloy
FitsXTR M980
ColorsBlack, Gold, Red
With the growing popularity of double chainrings, lots of people are trying to convert existing triples to doubles, XTR cranks present some particularproblems with this conversion. Kcnc has an elegant light solution that allows you to remove the large ring from your setup and use just the inner and middle to produce a well spaced double. The kit includes female bolts machined into exact fitting rectangle shapes to replace the outer ring on the spider. It also includes male chainring bolts for both inner and middle spider in matching anodized aluminum as well as the spacers that are required.
Comment on KCNC XTR Double Chainring Conversion
