KCNC VB1 Brake Lever Set
Weight per Pair48 grams
Material7075 aluminum
Lever End to Pivot92 mm
Bar Clamp Diameter22.2 mm
KCNC's VB1 brake levers are minimally designed and meticulously CNC machined in order to achieve the lowest possible weight. This design compromises no functionality, however. Locking lever reach adjusters and barrel adjusters are included, and the levers provide an ample perch for two or three fingers. The bar clamp and lever pivot are combined in clever fashion using a chainring bolt-style assembly, resulting in a clean look.
KCNC's brake levers are compatible with both linear pull cantilever brakes (V-brakes) and mechanical, cable actuated disc brakes. These levers are compatible with standard mountain brake cables and 5 mm brake housing.
To mount the VB1 levers to your handlebars, all that is required is a 4 mm hex wrench. Standard cabling and brake adjustment tools will also be needed for proper setup.
