Kcnc Titanium Cables
Titanium Brake and Shifter Cables
KCNCS's Titanium cables are a no hassle lightweight alternative to standard steel cables at less than half the weight. Being titanium they can be treated the same as steel cables, no need for special clamping methods and you can clamp and re clamp. The KCNC Titanium cables are also Teflon coated using a nano technology that resists clumping and wear that most Teflon coated cables see.
Package Contents
Each set comes with two gold Nano Teflon coated titanium cables.
Mountain / Road Brake Cables
KCNC's Titanium Brake cables are compatable with either road or mountain brakes. The cable itself has a sphere on one end which fits into either a mountain or road style alloy adapter. When installing place a small amount of grease either on the sphere or in the adaptor to prevent any creaking during braking.
Derailleur Cables
The derailleur cable set installation is the same as a standard steel cable set.
Weight 15g (Der.)
18g (Brake)
Material Titanium
Coating Gold Nano Teflon
Diameter 1.1mm (Der.)
1.5mm (Brake)
Length 2100mm (Der.)
1700mm (Brake)
Cable Weight Comparison
Weights are for sets of four cables.
Power Cordz
Brake, Derailleur
KCNC Titanium 33g
Steel 70g
DLC coated Steel 76g
