KCNC Teflon Mountain Brake Cable
KCNC Teflon Mountain Brake Cable Blue$7.00 In Stock
KCNC Teflon Mountain Brake Cable Orange$7.00 In Stock
KCNC Teflon Mountain Brake Cable Pink$7.00 In Stock
KCNC Teflon Mountain Brake Cable White$7.00 In Stock
Weight24 grams
Materialstainless steel
CoatingNano-Diamond Teflon
Length1700 mm
Diameter1.5 mm
KCNC's coated cables begin life as a traditional high quality stainless steel cable. These complete cables are then coated with KCNC's proprietary nano-teflon coating, which helps reduce friction in your bicycle's cable systems. Low friction cables allow for trouble free operation of brakes and shifters by reducing "noise" in these cable systems and decreasing stress and wear on the user-end components. These coatings are available in 6 different colors to complement various bicycles' paint schemes.
These mountain style brake cables are designed for use with common cantilever and linear pull brake levers, as well as some time trial brake levers. Each package contains a single cable and one matching aluminum cable tip.
Comment on KCNC Teflon Mountain Brake Cable
